Overview
Roles: Admin | Interface: Web
The Photo Library in CrewCenter Web is a central hub for Admins to manage, review and organize all project-related photos. This feature supports documentation, compliance and reporting by providing easy access to images uploaded from both the field and the office.
Note: Access to the Photo Library is controlled by a setting for each customer account and can be enabled by the support team. If you don’t see the Photo Library, please contact your sales representative to confirm that it is enabled for your account.
Photo Library Features and Purpose
The Photo Library allows Admins to:
- View all photos uploaded from mobile or web
- View images organized by days and for all or specific
- Open larger previews and browse through images
- Correct the assigned project and date of a photo
- Delete photos that are no longer needed
Photos are used for documenting progress, recording incidents or defects and supporting construction diaries and project reports.
Integration with Other Modules
Construction Diary: Photos become part of daily work context and can be included in reports.
Project Dashboard - Photos section: Displays all available pictures for the selected project and timeframe.
Reporting & Compliance: The Photo Library serves as a searchable archive for progress reviews, incident documentation and legal requirements.
Offline Behavior
The web Photo Library requires an online connection. Mobile uploads appear after successful upload to CrewCenter. To make sure the photos are uploaded and visible in the library, follow the instructions below:
- Always ensure you have a stable internet connection when using the web Photo Library for uploads or management. We also recommend opening the app daily and synchronizing the data to keep everything up to date.
On mobile, take advantage of offline queuing if you are working in areas with limited connectivity. Remember to open the app when back online to sync your uploads.
Add contextual information (project, timecard, notes) to images whenever possible to improve documentation quality.
Regularly check that your offline uploads have synced after regaining connectivity.
Sources of Photos in CrewCenter
Photos are uploaded by users from various locations:
Mobile (Android & iOS):
Roles: Admin, Supervisor, Employee | Interface: Mobile
From the LIVE tracking screen during work events
2. From the day view in the Timesheets page, where you open your timesheet and select a specific day.
3. From the Photo Library entry in the mobile menu
For Web
- Through web-based photo upload (where enabled)
2. Via modules such as Construction Diary
3. Via Project Dashboard – Photos section
Each photo is stored with its date, project, and additional metadata, which determines how it appears in the Photo Library and reports.
Photo Visibility on Mobile
Roles: Admin, Supervisor, Employee | Interface: Mobile (Android & iOS)
On mobile, users can only see photos that were uploaded from their own mobile device. This applies to Employees, Supervisors, and Admins.
Photo Visibility on Web
On the web, Admins can view all photos available for a specific project, including photos uploaded by other users.
Supported Photo Formats
CrewCenter currently supports the following image formats:
- PNG
- JPEG
- JPG
- SVG
- JFIF
- GIF
- BMP
- WEBP
The list of not supported file types: PDF, HEIC/HEIF, TIFF, ICO, EPS
Accessing the Photo Library
Open the Photo Library from the left navigation.
The Photo Library displays a grid of photo thumbnails for all available images.
Features include:
- Thumbnails for fast loading and improved performance
- Sorting by date, with the newest images first
Viewing photos for one specific project or all projects in the right top corner dropdown
Browsing and Previewing Photos
Open the Photos
Click a thumbnail to open the detail view.
The detail view shows the full image, assigned date and project.
Use arrows on your keyboard or swipe to move to the next or previous image.
Editing Photo Details (Date and Project)
If a photo was uploaded under the wrong project or date:
Open Photos.
Make sure you can see “All projects” in the top-right corner or navigate to the project that contains the image with incorrect data.
Click the thumbnail of the image to open its detailed view.
- In the detailed view, click the pen icon beneath the main image to enter Edit mode.
5. Click the date field to open the date picker or use the left and right arrows to select the correct date.
6. Update the project name if needed.
7. Click Update to save your changes.
Note: Changes are saved immediately and reflected across the Photo Library, Project Dashboard and other modules. Analytics events are sent when date or project is changed.
Deleting Photos
To delete a photo (reference to the screenshot under "editing photo details" section):
Open Photos.
Select one or more photos you want to delete.
Click Delete.
Confirm the deletion in the pop-up window.
Deleted photos are removed from the Photo Library, Project Dashboard and Construction Diary. Deletion is final from the UI.
Important Notes and Limitations
File size
The maximum picture size is 15 MB.
Access & Roles
The Photo Library is designed for Admins. Workers upload photos via mobile but do not manage the library on web.
System based "photos" feature activation
Performance
For faster browsing, the Photo Library pre-loads only reduced size thumbnail versions of your images in the grid view. When you click a thumbnail, the full‑resolution image will open in the detail view.
Troubleshooting
You cannot see Photo section
Contact your Project Manager or Administrator to check if your account has access to Photo Library.
The Photo is missing
Check the upload status:
When you added the picture, did you have an active and stable internet connection? Make sure the upload completed successfully and that the image appears in the Photo Library.
If the picture does not appear in the gallery after uploading, try reconnecting to the internet and upload it again.
Clear your app’s cache or refresh the page to ensure you’re viewing the latest data.
If the issue persists after retrying, please contact the support team for assistance.
Project selection: Make sure you chose the correct project in the top right dropdown or switch to “All Projects” to ensure the photo isn’t hidden due to the selected project.
Photo's details are incorrect
Photo Library – What Happens to My Photos?
Web Browser (PC/Mac)
✅ JPG / JPEG, PNG, GIF, BMP, SVG, JFIF
When you upload a photo through the web browser:
- Your photo keeps its original format, quality, and resolution.
- There is no compression, resizing, or conversion.
- Files up to 15 MB can be uploaded.
- A small thumbnail preview (up to 256 × 256 pixels) is automatically created for the gallery view, but your original photo remains unchanged.
iPhone / iPad (iOS)
✅ Photos from your camera or photo library in any common image format (JPG, JPEG, PNG, HEIC, WebP, GIF, BMP, and others)
- The app automatically optimizes every photo before upload to reduce storage usage and improve performance.
- Photos are converted to a JPEG image with reduced file size.
- The original dimensions are preserved (no resizing).
- Your original photo remains on your device and is not immediately removed.
Android
✅ Photos from your camera or gallery in any common image format (JPG, JPEG, PNG, HEIC, WebP, GIF, BMP, and others)
- The app automatically optimizes every photo before upload.
- Photos are converted to WebP format.
- Large images may be resized to improve performance.
- The optimized version is uploaded and used by the application.
Gallery View vs. Full Photo
- The photo gallery displays a small preview thumbnail for faster loading.
- Opening a photo shows the full stored image.
