Geofencing
On this page
    Overview
    Roles: Admin | Interface: Web
    Geofencing in CrewCenter helps you check whether employees clock in and out at the expected work location. It makes it easier for Admin to identify possible issues, verify working times and confirm that employees were present at the job site.
    Note: For Geofencing to be active, administrators must enable the Geolocation feature in Admin Settings.
    Configuring Project Geofences
    Geofences must be set up for each specific project. There is no default geofence radiuses.
    To configure the Project Geofence:
    1. Open the Projects menu.
    2. Select a project to edit or create a new one.
    1. Ensure the project has a valid address, meaning an address that can be found and selected when entering the project location. The geofence center is based on this location.
    2. Locate the Geofence toggle within the project settings.
    3. Define the Radius for the virtual boundary around the project center.
    4. Save the project settings to begin tracking location statues for that site.
    Projects with Geofence enabled are marked with a check mark on the Projects page.
    Note:
    • The maximum distance that can be set in the project settings is 999,999 m (approximately 1,000 km).
    • If no geofence is set up, the geofence status will not be available. A project address is required to set up a geofence.
    Geofence verification
    There are 4 geofence statuses:
    1. Start inside – The Clock In event occurred inside the geofence area but there is no data available for clock out event. This can happen in following cases:
    • Missing Clock Out event
    • Automatic Clock Out
    • Location deactivated while Clock Out (device)
    • Ongoing timecard
    2. Inside - Both the Clock In and Clock Out events were inside the geofence area.
    1. Outside – At least 1 event (Clock In / Clock Out) took place outside the geofence.
    1. No data – Location data was not available, so the geofence status could not be shown. This can happen in following cases:
    • Both the Clock In and Clock Out events are not available
    • Clock In event is not available but Clock Out event is Inside the geofence
    Geofence visibility
    Administrators can check an employee's geofence status in the following sections of the application:
    1. Map - When a geofence is added to a project, the Map page shows a radius around each employee’s location, but only Outside events have a chip, to guide your attention to where it matters.
    Note: The map in the widget zooms in to display the project location pin and event pins.
    2. Timecard details – The geofence displays the status for each clock-in and clock-out event for every project throughout the day.
    Note: Detailed location coordinates are deleted after 90 days, but geofence statuses are retained.
    3. Timesheet – The Work view includes a Geofence column displaying verdicts.
    Users can filter employees by those Inside, Outside or without a defined geofence.
    Note: When an Admin or Supervisor clocks in or out for multiple employees using Bulk Mode, the Admin's or Supervisor's location is applied to all employees included in the bulk action. As a result, all affected employees will receive the same geofence status, such as Inside or Outside.
    Example:
    Anna Kotenta performed a bulk clock-in and clock-out for several employees, as she is working on site with her crew. . After clocking them out, the employees appeared on the Work page with the same geofence and address.
    The timecard history make transparent, if a timecard was created by the individual employees for themselves or by another user for others.
