Overview
Roles: Admin | Interface: Web
This guide provides a walkthrough for new users to set up and begin using CrewCenter. Following these steps ensures that administrators and supervisors can manage time tracking, projects, and employee assignments immediately.
Create Employees
Before employees can start using CrewCenter, you need to add them to the system. You can create employees individually or import multiple employees at once.
Create an employee manually when you want to add one person and configure their details manually.
Import employees in bulk when you need to add multiple employees at once. After the import, you can edit each employee to set their category and position.
Note: If you enable application access, make sure you enter the correct email address. CrewCenter sends the registration email to this address, and the email address cannot be changed later.
See more: How to manage employees
Create Projects
Projects help organize work in CrewCenter and ensure that working time and costs are assigned correctly.
You can create a project manually or import multiple projects at once. When creating a project, you define its basic information and decide whether it should be available to all employees or only to selected employees.
Watch the video below to learn how to create projects in bulk.
Important: Each project must have a unique project number. Projects cannot be deleted once created, but they can be set to inactive when they are no longer needed.
See more: Projects (objects) in CrewCenter
Add Working Schedule
A working schedule defines the expected working hours for employees throughout the year. CrewCenter uses these hours to correctly calculate working time, overtime and absences.
You can create different schedules for different groups of employees, for example, full-time or part-time employees. Each employee can be assigned to one working schedule per year.
Important: Make sure employees are assigned to the correct schedule. Without a working schedule, their expected working time is set to 0, which affects time and absence calculations.
Add Public Holidays
Public Holidays help you manage holidays and ensure they are correctly reflected in employee timesheets.
Watch "How to Create and Manage Public Holidays" to learn how to create a Public Holiday calendar, add or import holidays, assign employees and manage how holidays affect expected working time.
See more: Annual working schedule
Add Pre-set Breaks
Pre-set Breaks automate the recording of regular breaks and reduce the need to add breaks manually. They can be used, for example, for fixed breakfast or lunch breaks.
Important: All breaks must be taken within working hours.
Watch "Activate Pre-set Breaks" to learn how to activate this feature and configure company-defined breaks.
Once activated, users can use company Pre-set Breaks, create their own personal breaks, or disable Pre-set Breaks.
Note: Admins activate and configure Pre-set Breaks on the Web app, while Pre-set Breaks are used in the Android and iOS apps.
Add Special Types of time
Special time types help you track activities that are different from regular working time, such as driving, training, or other specific work activities. As an Admin, you can create special time types that match your company's needs and make them available to employees when they report their time.
You can also decide whether a special time type should be included in the total working hours or excluded from totals.
The following video shows how to create a new special time type and exclude it from total working hours.
Remember: When Excluded from totals is selected, time recorded under this special time type remains visible in the timesheet but is not included in the total working hours.
See more: Special Time types in CrewCenter
Absence Reporting
Absence reporting allows employees to report time away from work, such as holidays or sick leave, while giving Admins and Supervisors a clear overview of employee absences.
As an Admin, you can create the absence types your company needs, manage how they are used, and review reported absences in the Timesheet.
Create absence types
You can create different absence types to match your company's needs, for example Holiday or Sick Leave.
Once configured, these absence types are available to employees when they report an absence. Employees can also report future absences, making it possible to record planned time off in advance.
Watch the video to see how to set up absence types and how employees report an absence in the mobile app.
Review and approve absences
Reported absences can be reviewed in the Timesheet, giving Admins an overview of employee absence records.
Watch the video to learn how to find reported absences in the Timesheet and approve them.
Remember: Working schedules and absence reporting work together. Make sure employees are assigned to the correct working schedule so that their expected working hours and absences are calculated correctly.
See more: Absences in CrewCenter Web and Mobile
Add Cost Codes
Cost codes help you categorize reported working time by activity or project stage, for example Excavation, Formwork, or Concrete Pouring. This provides a more detailed view of how working time is spent within a project.
Cost codes are created and managed by Admins in the Web app and can then be used when reporting time on Web or Mobile.
Remember: A project shows where the work is performed, while a cost code describes what type of work is performed.
Watch the video to learn how to create and configure a cost code.
Import cost codes in bulk
If you need to create multiple cost codes, you can import them at once instead of creating each one manually.
Download the CrewCenter import template, add your cost code information, and upload the completed file.
Watch the video to learn how to import multiple cost codes in bulk.
Remember: Cost codes allocate time within an existing time entry. They do not create additional working time.
See more: Cost Codes in CrewCenter
Add Costs&Quantities
Costs & Quantities help capture additional expenses and outputs related to daily work and projects.
As an Admin, you can create and manage the items your company needs. For example, you can track expenses such as accommodation or mileage, as well as quantities such as hours, kilometers, or completed work.
Once configured, Costs & Quantities can be reported as part of daily work on Web and Mobile
See more: Costs and Quantities in CrewCenter
Export Reports
Configure exports
Once working time and absences are recorded in CrewCenter, you can export the data for payroll, reporting, or further processing in other systems.
CrewCenter provides several standard export templates, including Excel reports and formats designed for data transfer to external systems. As an Admin, you can select the template that best fits your needs and configure the employees, projects, time period, and data to include.
See more: How To Export Timesheets from CrewCenter Web
Watch the video to learn how to configure and generate a timesheet export in CrewCenter.
Note: Subscribed users: if the standard export templates don't meet your company's requirements, contact the CrewCenter Support Team at support@crewcenter.com to discuss a custom export report tailored to your needs.
