How to do bulk operations in CrewCenter
On this page
    Overview
    Roles: Admin, Supervisor | Interface: Web
    This article explains how administrators and supervisors can use bulk actions in CrewCenter to manage multiple records at once, reducing the time needed for repetitive tasks.
    Available Bulk Actions
    • Adding Time Entries
    • Deleting Time Entries
    • Approving Timesheets
    • Revoking Timesheet Approvals
    • Assigning Employees to Projects
    • Creating Employees
    • Creating Projects
    • Importing Cost Codes
    • Downloading Multiple PDF Reports
    • Deleting Multiple PDF Reports
    • Exporting timesheet data in bulk
    How to add time entry in bulk
    To add the time entry in bulk:
    1. Open Timesheets
    2. Select employees by ticking the box next to their name
    3. Click Add Time Entry
    4. Choose the required day(s) from the calendar in the side panel
    5. Select the project, then enter the clock-in and clock-out times
    6. Click "Report" button to submit
    Note: Selection is limited to the current month view; navigating to a different month will clear the selection.
    See more: How to add/edit time entries in POST Mode
    Step-by-Step Video Guide: How to Add Time Entries in Bulk
    For a larger view, please use the button below:
    How to delete (clear) the time entry in bulk
    As an Admin or Supervisor you have the ability to select an entire week and clear the data for one or more employees, provided that the timesheets have not been locked or approved.
    To perform this action:
    1. Open Timesheets
    2. Select the employee (employees) by ticking the box next to their name
    3. Click "Clear" on the top bar
    4. Tick "Clear time reports" on the pop- up which display and confirm the Clear action
    If the timesheet was approved already click selected employees and hit "Revoke approval" on the top bar. Then perform the clear option
    Note: The bulk-delete confirmation window indicates that only Pending timecards will be deleted. Approved and Locked entries are skipped.
    Step-by-Step Video Guide: How to delete (clear) the time entry in bulk
    How to approve time in bulk
    1. Open Timesheets
    2. Select one or more employees
    3. Click Approve
    Use this action to approve all selected employee-day combinations.
    Note: Approving time in bulk is visible when at least one selected record has the status Pending.
    See more: Approving Time Entries and Absences
    Step-by-Step Video Guide: How to approve time in bulk
    How to revoke the approval in bulk
    1. Open Timesheets
    3. Click Revoke approval
    Note: Revoking the approval is visible when at least one selected record has the status Approved.
    Step-by-Step Video Guide: How to revoke the approval in bulk
    How to assign employees to project in bulk
    1. Open the Projects page in the Web application
    2. Click Create to start a new project
    3. Fill in the mandatory fields: Project Name and Project Number
    4. Scroll to the Assigned Employees section
    5. Choose how to assign employees:
      • Option A — Assign all employees: Turn the Assign all employees toggle ON. All employees will be assigned automatically
      • Option B — Assign selected employees only: Turn the toggle OFF. Manually select the employees you want to assign to the project. You can search by name or ID
    Note: You can change the employees assigned to a project after the project has been created. To do so, go to Projects, click Edit to open the project details, and scroll to the Assigned Employees section. There, you can update the assigned employees by selecting One, All, or Selected employees.
    See more: How to assign employees to projects
    Step-by-Step Video Guide: How to assign employees to project in bulk
    How to create employees in bulk
    As admin or supervisor you can download the file template and create employees in bulk.
    1. Go to Employees > + Create > Import
    2. Click Download File Template and open the downloaded .xls file
    3. Complete the template and fill required fields: First Name, Last Name
    4. Return to the Import page and click Drag & drop file here, or click here to browse
    5. Select your completed file and click Open
    6. The file is imported automatically, and new employee records are created
    7. A confirmation pop-up displays the number of employees successfully imported
    See more: How to import the file template for importing employees
    Step-by-Step Video Guide: How to create employees in bulk
    How to create projects in bulk
    You can create projects in bulk.
    1. Open the Projects tab on the left side of the Web app
    2. Hover over "+ Create" and click Import
    3. Download the provided template in xls
    4. Fill the template with the following details: Project Name, Project Number and Cost Center ID
    5. Save the file to your local device
    6. Upload the completed template by clicking on the Drag&Drop area and verify the imported projects in the Projects tab
    See more: Import Projects via Excel
    Step-by-Step Video Guide: How to create projects in bulk
    How to import cost codes in bulk
    Roles: Admin | Interface: Web
    You can import multiple cost codes at once by downloading a template, completing the required information, and uploading the file back into CrewCenter.
    1. Go to Cost Codes > + Create > Import
    2. Download the template and complete the required fields: code and name
    3. Upload the completed Excel file on the Import page
    See more: Enabling and Managing Cost Codes (Web)
    Step-by-Step Video Guide: How to import cost codes in bulk
    How to Download Multiple Daily reports in PDF
    As a supervisor or administrator, you can download multiple PDF reports at the same time.
    1. Go to Daily Reports tab
    2. Open the PDF Reports table
    3. Select the reports using the checkboxes
    4. Press download
    Note: CrewCenter creates a ZIP file containing all selected PDF reports.
    See more: How to manage PDF files
    Step-by-Step Video Guide: How to Download Multiple Daily reports in PDF
    How to Delete Multiple Daily reports in PDF
    As an administrator, you can delete multiple Daily PDF reports at the same time.
    4. Press delete
    Step-by-Step Video Guide: How to Delete Multiple Daily reports in PDF
    How to export Timesheet data in bulk
    As an administrator, you can export timesheets in bulk for a single employee, selected employees, or all employees.
    To do it follow steps:
    1. Open the Timesheet tab
    2. Click Export
    3. Select the export type and time period
    4. Select the employees whose timesheets you want to export
    5. Choose how the results should be displayed and which fields to include in the export
    6. Click Export to generate the file
    See more: How To Export Timesheets from CrewCenter Web
    Step-by-Step Video Guide: How to export Timesheet data in bulk
