2026.07.06 Release
On this page
    Overview
    This release improves reporting, time tracking, and employee management. It also adds more flexibility to exports and enhances Construction Diary (daily reports) workflows. Here are the changes from the previous CrewCenter version:
    • Construction Diary (daily reports): Added time types, improved PDF management, and enhanced template-based reporting.
    • Absence & Attendance: Excluded time types can now be tracked without affecting worked hours.
    • Employee Profiles: Added customizable Categories and Positions for employees.
    Construction diary (daily reports) - "Types of time" added
    Roles: Admin | Interface: Web
    Admins can now distinguish between regular and excluded time entries in the Types of Time widget. Excluded entries are labeled accordingly, can be shown or hidden with a checkbox, and are excluded from the payable hours total.
    Construction diary (daily reports) - Costs & Quantities in PDFs
    Construction Diary (daily reports) PDF reports now support Costs & Quantities widgets, displaying each configured category as a separate section with detailed item information, including name, category, code, value, and unit.
    Construction diary  (daily reports)  - Template-aware calendar indicators
    The Construction Diary (daily reports) calendar picker now displays status indicators for generated PDFs. A blue dot shows that a finalized PDF exists, while a grey dot indicates that only a draft is available. Indicators automatically update when switching projects, templates, or calendar months.
    Construction diary (daily reports) - new 3-dot menu and bulk actions
    Users can now View, Download, Share, and Delete individual PDF reports via a 3-dot menu.
    Multiple reports can also be selected for bulk download as a ZIP file or bulk deletion with an additional confirmation step.
    To download PDF reports in bulk:
    1. Choose the PDF reports you want
    2. Click download.
    The PDF reports will be saved to your computer.
    To delete PDF reports in bulk:
    2. Click delete.
    Absence & Attendance reporting - Excluded Times added
    Roles: Admin, Supervisor, Employee | Interface: Web, Mobile
    Admins can now configure specific work time and absence types as excluded, allowing unpaid or non-working periods to be documented without increasing worked hours. Excluded time is clearly marked across the web and mobile apps, excluded from time calculations, and supported in reporting and exports.
    Key benefits:
    • Flexible configuration: Define work time and absence types as excluded in your tenant settings.
    • Accurate calculations: Excluded time is recorded but not counted toward worked hour totals.
    • Clear visibility: Excluded entries are clearly marked across timesheets, timecards, and absence records.
    • Reporting support: Excluded time is handled correctly in reports and exports, with the option to include or exclude these entries.
    • Mobile support: Record and track excluded time in both Live Tracking and Post Mode. During live tracking, excluded periods are logged while worked hour calculations are paused.
    • Excluded absences: Absences marked as excluded are visible throughout the application but are not included in absence totals.
    Live tracking to excluded time:
    Timecard with Excluded time:
    Excluded absence:
    Employee Management: Category & Position
    Roles: Admin, Supervisor | Interface: Web
    Admins can now assign a Category (e.g., Internals, Subcontractors, Apprentices) and a Position (e.g., Electrician, Scaffolder) to employee profiles using an autocomplete combo box. Both fields are optional.
