2026.10.07 Release
On this page
    Overview
    This release improves CrewCenter’s performance and visibility. Construction Diary PDFs are now generated asynchronously to handle large reports efficiently and a Map Widget has been added to timecard details to help approvers verify locations.
    Key Changes:
    • Construction Diary: Asynchronous Construction Diary PDF Export (Web)
    • Timecard: Map Widget in Timecard Details (Web)
    Roles: Admin, Supervisor, Project Manager | Interface: Web
    Construction Diary PDF exports now process in the background, allowing you to continue working. You’ll be notified when the file is ready or can check its status to download it. This prevents timeouts for large reports.
    Notes: Concurrent export limits apply: 1 for free trials, 10 for paid tenants.
    Roles: Admin, Supervisor | Interface: Web
    A new Map Widget in the timecard details panel shows clock-in and clock-out locations alongside the project location, helping approvers quickly verify work locations and streamline timesheet approvals.
    Notes:  The widget is only visible if the Geolocation admin setting is enabled.
